Re: Super A throttle?
Posted by big fred on June 11, 2000 at 15:20:22 from (208.51.245.50):
In Reply to: Super A throttle? posted by Shawn Simoneau on June 11, 2000 at 14:53:47:
I would guess you have a governor problem. First, though, check the linkage between the governor and carb for free movement. If there is no binding, then check the governor. My guess is the spring is busted. It can be a relatively inexpensive fix, as the spring is pretty cheap, but you may find other problems when you get into it. You can remove the governor without removing the radiator.
Post A Followup
: Re: Re: Super A throttle?
