Re: M clutch repair
Posted by Janicholson on August 17, 2010 at 14:02:52 from (199.17.6.223):
In Reply to: Re: M clutch repair posted by rustred on August 17, 2010 at 07:25:18:
Either of these will require a split of the tractor. But do it if it needs it.
Blue spots on the FW, or a wear spot or groove wider than an eithth inch, or deeper than .010, would influence me to split it for a resurface. Be careful to keep the clutch PP surface to friction surface stock. (step depth) Jim
