Re: M clutch repair
Posted by dougct on August 17, 2010 at 15:24:44 from (76.119.93.170):
In Reply to: M clutch repair posted by Firechief135 on August 17, 2010 at 06:15:36:
You need to find out if you have a 11" or a 12".You don"t have to split the tractor for and 11".A 12" you must split the tractor.More than likely you have an 11.
