Re: Cub suddenly dies
Posted by El Toro on August 18, 2010 at 03:33:17 from (74.103.74.58):
In Reply to: Cub suddenly dies posted by kdg on August 17, 2010 at 19:47:23:
You could try the old condenser, but I think you have a fuel problem since it will restart. Pull the gas line at the carburetor and see if there's a full stream of gas from the tank. If there's full stream from the tank remove the tube fitting at the carburetor and see if there's a screen behind that fitting that's plugged. If that looked ok your carburetor probably needs to be soaked in carb cleaner and the jets blown out with air pressure. Hal
