Re: Starting a 140 after it caught fire............
Posted by AL Farmall Boy on August 18, 2010 at 08:38:49 from (74.248.177.77):
In Reply to: Starting a 140 after it caught fire............ posted by AL Farmall Boy on August 18, 2010 at 08:16:26:
List of NEW Parts (pertaining to engine):
Starter Solenoid
Key Ignition Switch
Coil (with built in resistor)
Set of Plug Wires
Distributor Cap, Rotor Button, Points, Condenser
Radiator Mounting Pads (set of 2)
Oil Pressure Gauge
Water Pump
Thermostat
Radiator Hose (upper)
Radiator Hose (lower)
Spark Plugs (4)
Oil Filter
Fuel Sediment Bowl
Carburetor
Fuel Line (flexible)
Fan Belt
