Re: Starting a 140 after it caught fire............
Posted by AL Farmall Boy on August 18, 2010 at 08:46:09 from (74.248.177.77):
In Reply to: Re: Starting a 140 after it caught fire............ posted by AL Farmall Boy on August 18, 2010 at 08:41:32:
Here is a list of USED PARTS we installed:
Starter (original ok)
Valve Cover
Fuel Tank
Hydraulic Reservoir Box
Hydraulic Lines/Manifold
Distributor (inside parts new)
Radiator (repaired original)
Complete Wiring Harness
Steering Shaft Support Collar
