Posted by Armand Tatro on August 18, 2010 at 16:55:07 from (98.227.136.134):
In Reply to: Windbreaker? posted by 660 guy on August 18, 2010 at 14:15:09:
Allan is right. However I (and others) have been known to use side-mounts as rear-mounts as well and use John Deere wind breaks on I H and viceversa. When it is cold, miserable, and nasty one tends to make do with what is handy. Armand
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
