Re: Cub suddenly dies
Posted by jaycow on August 18, 2010 at 19:53:12 from (96.249.120.248):
In Reply to: Cub suddenly dies posted by kdg on August 17, 2010 at 19:47:23:
Sounds like the same problem I had with my 140 -
Seems like rust would plug up screen on sediment bowl - got tired of stopping and starting,cleaning rust.
Solution: removed sediment bowl and shutoff - installed in-line filter - you can probably find some kind of shutoff that would work for you.
I even swished fiberglass resin around in the tank to no avail. Imagine keeping tank full would inhibit the rust problem.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
