Posted by The Dukester on August 19, 2010 at 10:54:28 from (207.69.140.36):
In Reply to: measuring a carb posted by Charles E. McNelly on August 16, 2010 at 19:34:12:
It's kind of a "nominal" size, like pipe sizes are, meaning that it's the area of a 1 1/4 bore with the consideration of the area with the inserted throttle shaft's area subtracted...so the measured diameter is greater to allow for that. Naturally the minimum size in the venturi is somewhat less, couldn't be a venturi if it wasn't.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You
... [Read Article]
Latest Ad:
[More Ads]
