Re: Removing hydrualic pump Farmall Super M
Posted by glennster on August 19, 2010 at 11:05:39 from (76.222.58.114):
In Reply to: Removing hydrualic pump Farmall Super M posted by farmallray on August 19, 2010 at 10:14:44:
you will need the spacer that goes in there. i-h calls it a distributor bracket. you will need one off a super m, not an m unless it is a very late m, as the mounting bolt holes to the block are drilled different.
