Posted by 36F30 on August 19, 2010 at 17:44:54 from (71.214.215.150):
In Reply to: Stuck 22-36 Engine posted by Tom in Iowa City on August 19, 2010 at 17:28:18:
Take the rod caps off and see whats stuck. I have had them so bad two sleeves were broken in the middle and the two on the ends pushed out and were good enough to reuse, pulled those sleeves with a sleeve puller. The other two I had to torch because they were stuck at the bottom of the stroke. On another I took a 2" wide 1/2" thick steel bar and put it on the lip of the sleeve and drove it out with a maul. once you break the o ring and crud they come right out and you can then heat the sleeve with a torch and push them out the bottom or break the sleeve to get the piston.
This post was edited by 36F30 at 17:46:16 08/19/10.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
