Re: Farmall M front end bounceing in high gear.
Posted by CNKS on August 19, 2010 at 18:10:07 from (216.144.104.128):
In Reply to: Farmall M front end bounceing in high gear. posted by farmallray on August 19, 2010 at 10:19:57:
The others are correct, no one is trying to be funny. Is your wheel cast or pressed steel? The steel one would be pretty light, the cast one is probably heavier than the ones on the NF. Ours had the cast one. If it bounced, I slowed down. But, it did not behave any different than the NF.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
