Re: Stuck 22-36 Engine
Posted by Nebraska Kirk on August 19, 2010 at 19:26:02 from (207.91.4.193):
In Reply to: Stuck 22-36 Engine posted by Tom in Iowa City on August 19, 2010 at 11:14:28:
Here is what I did on two badly stuck Regular pistons, I took the rod caps loose first, then I took a long rod and placed one end against the wrist pin retaining bolt head and hammered on the rod with a big hammer, the piston and sleeve began moving after 2 or 3 big licks and came totally loose after a few more hits. I then placed the sleeve/piston assembly in my press and pressed the piston down and out of the sleeve, I did not damage either the piston or sleeve.
This post was edited by Nebraska Kirk at 19:28:06 08/19/10.
