Re: 12 volt motor to run water pump
Posted by John T on August 20, 2010 at 09:10:33 from (66.244.97.31):
In Reply to: 12 volt motor to run water pump posted by Mike In Kentucky on August 20, 2010 at 08:25:59:
Im all for using stored battery energy to run horsepower robbing water pumps and fans while pulling versus using precious engine HP to do so. I wouldnt even be using engine power to run the genny or alternator while pulling, a battery can easily run the fan and pump water for a short pull. 12 VDC RV water pumps can supply something like 5 GPM at 30 PSI while a 12 VDC electric fan supples all the air needed through the radiator.
Go for it, unless you like wasting engine HP when its not needed.....
John T
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
