Posted by gene bender on August 20, 2010 at 10:30:47 from (67.55.227.196):
In Reply to: Will it Fit ??? posted by farmerjohninpa on August 19, 2010 at 19:44:47:
DO NOT get one from the C as the steering sector is different. Do put one from the A. Gaet enerything from the steering wheel forward. If you want the front tread to be the same as the rear it will turn funny as the distance from the output shaft will be wider on one side . Most just set the wheel tread both side same distance. I have one to do that way owner just want a wide front on his B.The grill is different on the A but you can cut the Bs and make it fit around the steering sector. Everything will bolt up but the grille.Mite want to go thru the As steering sector replace seals and so forth. Make sure the spindles on the A get grease to the bottom where the wt rides sure makes them steer better. I have went both ways either butting one on ar taking one off and then adding the narrow front. e-mail is open
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
