Re: hot coil part 3..
Posted by Bob M on June 12, 2000 at 05:32:18 from (192.232.120.194):
In Reply to: hot coil part 3.. posted by gn on June 11, 2000 at 20:12:38:
GN - Here's how to determine coil/breaker point voltage: 1 - Connect one voltmeter lead to each of the two primary terminals on the coil. 2 - Pop the distributor cap, then manually rotate the crankshaft and observe the points - stop when the ignition points are closed. 3 - Now turn on the ignition - the voltmeter will read the voltage at the coil. Assuming you've got a 6 volt coil and ballast resistor, the meter should read somewhere near 6 or 7 volts. If it reads much higher than that, you've got a wrong (too low resistance) ballast resistor installed. Wire gage does not affect coil voltage unless wire gage is grossly undersized - in which case the wiring itself will get hot. Hope this helps...
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
