Farmall B mag. again!!!
Posted by bkpigs on August 20, 2010 at 18:19:57 from (75.132.223.199):
Ok, so I finally got spark to the supply wire for the dist cap. Only problem is the spark is only about 1/8". I put a new condensor in it but that was when I wasn't getting anything. I am going to put the old one back in and see if it improves. Sound like an idea to you guys?
I found out my original problem was that I put the hot wire for the spring side of the points on backwards and it let the spade connector arc to the body of the mag.
I never would have guessed that while doing a simple routine maintanence task something could get soo screwed up.
Thanks for your time AGAIN!!!
