Re: belt on woods mower
Posted by Haas on August 20, 2010 at 19:28:01 from (75.216.242.244):
In Reply to: Re: belt on woods mower posted by tractorhead on August 20, 2010 at 07:17:37:
You need to use a pry bar or a jack to push down that idler pulley when you tighten the belt. Otherwise, you will not get it tight enough. Also always tighten be belt when the mower is in the raised position. The belt has to the TIGHT!!
