Posted by Tom Fleming on August 20, 2010 at 19:37:44 from (206.193.253.243):
In Reply to: F20 Starting troubles posted by Jay Snyder on August 20, 2010 at 19:13:00:
Sounds like your timing is off. Get #1 cylinder on TDC for the compression stroke. Take #1 plug out, and crank over with your thumb over the plug hole. when you feel it pressure up, you are on the compression stroke. Use a wire in the plug hole to determine when you are on TDC.
Now, take the cap off the mag. Is it pointed at #1 plug? Did the mag impulse just trip when you got to TDC? if the answer to these is NO, then your timing is off and will produce the symptoms you are describing.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
