Re: Farmall M front end bounceing in high gear.
Posted by 3500sport on August 21, 2010 at 06:15:18 from (173.216.7.1):
In Reply to: Farmall M front end bounceing in high gear. posted by M Stepan on August 19, 2010 at 10:19:57:
I took my m wide open in Fifth yesterday with my narrow front and she didn't wobble at all...
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
