Re: Grill for Farmall H
Posted by rustyfarmall on August 21, 2010 at 07:31:18 from (209.152.78.140):
In Reply to: Grill for Farmall H posted by randy hall on August 20, 2010 at 23:20:00:
Exactly. Although the dzus fasteners are not a problem because the holes are in the same place and you can use the bolts instead, but the lack of the slot for the radiator overflow tube is a problem, but that could also be remedied if you are determined enough.
