Re: will it work ? will it hold up?
Posted by rustyfarmall on August 21, 2010 at 14:11:59 from (209.152.78.140):
In Reply to: will it work ? will it hold up? posted by tn terry t on August 21, 2010 at 13:44:09:
The fast hitch was an option, and if the 560 did not have the fast hitch, it would have come with the same type of drawbar arrangement as the H or the M, but also, I think the 560 SHOULD have a drawbar totally independent of the fast hitch, and that was what was supposed to be used when pulling tillage equipment or pto driven equipment. I doubt if the horseshoe drawbar from an H would be quite strong enough. It would eventually bend in the middle from the tongue weight. The horseshoe drawbar for the 560 was heavier.
