Re: Atten: Owen Aaland and/or D. Slater
Posted by pete 23 on August 21, 2010 at 17:39:08 from (173.87.8.216):
In Reply to: Atten: Owen Aaland and/or D. Slater posted by Spotted Horse on August 21, 2010 at 08:15:13:
Yes, the spool is behind the plug with a snap ring on it. It is actally the priority valve and the rest of the components inside the valve block are regulator valve, relief valve, screen orfice and power steering relief valve. The lands in the bore where priority spool moves in can get worn also. I have not had a valve rebuilt but no doubt they will wear out with use and age, and have heard on this forum that there are machine shops that can rebuild them. When IH made this spool available for service it was a god sent as it made a lot of power steering systems work again without replacing the entire valve assembly. Some times, at this late stage, it does not do the trick though.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
