Re: My Electrical Stupidity
Posted by teddy52food on August 21, 2010 at 18:54:59 from (68.169.216.43):
In Reply to: Re: My Electrical Stupidity posted by JMOR on August 21, 2010 at 16:40:57:
The tester I have flashes when connected to the wire & body of a condenser. It will only flash once on a good condenser. If it flashes over and over again, the condenser is leaking. If it continues to glow , the condenser is shorted. There is a flow or the bulb wouldn't flash. A good ohm meter will deflect the needle too when first hooked up. If you ever test a large oil - filled motor capacitor you will see a large flow until it's capacity is reached.
