Re: Electronic Ignition Going Bad??
Posted by Janicholson on August 21, 2010 at 19:04:06 from (67.72.98.45):
In Reply to: Electronic Ignition Going Bad?? posted by TomH in PA on August 21, 2010 at 17:42:53:
Check the ballast resistor if it has one, it may be opening when it begins to warm up. If none, I would put a test light on the hot lead going into the module, and watch it for staying lit. If it goes out, it may be the ignition switch. Jim
