Posted by Janicholson on August 21, 2010 at 19:13:52 from (67.72.98.45):
In Reply to: Farmall A Kerosene posted by Sherry O on August 21, 2010 at 18:24:10:
Most of them are Distillate, or Kerosene fueled. They will run on gasoline just fine. If it is running and has great tires, straight tin, good clutch, and seems to not smoke. it is probably worth 1500. If tires are toast, take off 700, if the engine is stuck take off 1000. If all of the above, it should be sold for the scrap price (weight of iron times current scrap price.) possible 250. If it was well restored (new bearings in trans, all worn gears replaced, new tires, engine rebuilt with everything from crank to valves in perfect shape, with good paint prep and good paint. Probably 2500 to 3000. It will not be making money if sold. It will however be a fine tractor for a small patch of land. It will also keep him off of the street. Go for it. Jim
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
