Posted by Janicholson on August 21, 2010 at 19:40:05 from (67.72.98.45):
In Reply to: Thermostat on an H posted by David A. Smith on August 21, 2010 at 13:46:25:
It is held in with a wire ring 9you might have to dig for it, or it might be a ring of corrosion and needs "chipping" out. The higher heat is correct. be sure to put it in with the heat capsule toward the engine.
When alcohol was used as the antifreeze (ethylene Glycol was not invented) it was necessary to keep engine temps as low as was possible and still run OK. Thus the other range. Not a good idea, as it will make it run less efficiently. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
