Re: My Electrical Stupidity
Posted by JMOR on August 22, 2010 at 09:41:57 from (72.190.67.150):
In Reply to: My Electrical Stupidity posted by El Toro on August 21, 2010 at 08:17:57:
Janicholson said: (quoted from post at 11:46:47 08/22/10) The following scope patterns illustrate our point, the intermediate pattern, after the firing line extinguishes, is a trace of the energy in the coil dissipating through resistance/heat as the current charges and discharges (oscillates) into and out of the condenser. Not through it! With respect, Jim
PPT of issue Look at 8 7
If no current ever passes through the capacitor, then don't even connect a current carrying conductor to it!!! Go put a clamp on amp probe on it for Christ sake and measure it! Unbelievable!
Make it real simple: connect a capacitor, an ammeter (ma scale) and a battery in a series loop...if the ammeter needle jumps when you connect & reverse connect the battery, then you will have observed current flowing THROUGH the capacitor and you WILL observe that.
Charge on a capacitor is Coulombs. Current is Coulombs per second. No current flow??? Current only flows in a closed loop.
This post was edited by JMOR at 14:35:19 08/22/10 2 times.
