First off sounds like you need a manual the I-T IH-8 is a good one and can be picked up at most good farm and home stores. There is 2 or 3 pages in it that tell you how to adjust the gov to the carb and if the carb has been off for any reason it needs to be done or you can run into problems like your having. Plus if it has been off I'll bet the control from the carb to gov are not lined up correctly and that will cause that problem. BTDT or should I say a friend installed the carb I had to fix his mistake
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
