Re: Farmall M Tractor
Posted by CNKS on August 22, 2010 at 10:57:39 from (216.144.104.128):
In Reply to: Farmall M Tractor posted by Picklesmith on August 22, 2010 at 10:48:34:
By reconditioned, I suppose that means painted from 10 feet away -- better look for another tractor. Or have the "reconditioner" pull the trans cover and fix it. Usually when it doesn't shift properly, the problem can be fixed by removing the gearshift lever, and possibly the belt pulley and lining the shift rails up. This one sounds like more of a problem. The carb has easy to adjust idle speed and mixture controls -- in this case it sounds like the rod from the tang on the carb to the rod going to the governor is not connected properly.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
