Re: H axels leaking oil
Posted by gene bender on August 22, 2010 at 11:25:00 from (67.55.227.196):
In Reply to: H axels leaking oil posted by BIGDADDY4430 on August 22, 2010 at 07:43:20:
Its way more than that. The oil is coming from the tranny and thats where the leak is not supposed to be coming out the end of the axle that area does not have tranny grease there. You need to remove the axle housings to get to the seal. Only lube at the end would be grease from the outer bearing no tranny oil.
