Posted by gene bender on August 22, 2010 at 11:35:42 from (67.55.227.196):
In Reply to: Farmall A Kerosene posted by Sherry O on August 21, 2010 at 18:24:10:
The A should have the distillate manifold along with the shuttersin working condition. As far as the heads they were the same as the gasolene models just had different pistons with a dish inward compression was real low. Your chances of finding one that is all there to burn the fuel will be almost nothing as over the yrs stuff got broke taken off and just lost. You also need the carb with adjustable main jet good luck in finding one thats ready to run.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
