Re: Farmall A Kerosene
Posted by NDS on August 22, 2010 at 14:15:56 from (98.81.81.96):
In Reply to: Farmall A Kerosene posted by Sherry O on August 21, 2010 at 18:24:10:
When I bought my A in sixtys it would have been just what you are looking for. Back then it was just an old tractor to cut grass with and like most of the other ones shutters were taken off sometime and have disappeared so has small gasoline tank manifold rusted out and was replaced with gasoline manifold and now it is like vast majority of the old distilate/kerosene tractors. Tractor was kept in Dads shed and parts probaly got swept up in one of his occassional clean ups.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
