Re: My Electrical Stupidity
Posted by Gene-AL on August 22, 2010 at 15:33:49 from (98.83.64.178):
In Reply to: My Electrical Stupidity posted by Ste_fano on August 21, 2010 at 08:17:57:
With a wet distributor cap or rotor insulation material, high-voltage energy from the coil's field collapse as the points opened was being lost through a water path on the distributor cap or rotor insulator surfaces to ground. As a result, high voltage from the coil secondary could never rise enough to jump the distributor rotor plus the spark plug tandem gaps. Wet surfaces conduct high voltages very well.
A persistant arc across an insulator will eventually create a carbonized path that makes the part unusable unless the carbon can be removed (Carbon tracks). A tempoary fix, that sometimes will work is to scrape the carbonized material off. BTDT
