Re: WD9 diesel pump
Posted by Janicholson on August 22, 2010 at 16:52:33 from (67.72.98.45):
In Reply to: WD9 diesel pump posted by Ethan Chamberlain on August 22, 2010 at 11:25:57:
There are seals and gaskets inside between components (usually the input from the fuel pump to the plunger.) check out caseih.com for parts diagrams. It is not rocket science, just clean it, take it off with the engine at TDC #1 (use the gas starting position to determine that) take it apart clean (take pictures), and go back together with new seals and gaskets. Jim
