Re: Which dist. does my farmall 300 have
Posted by Owen Aaland on August 22, 2010 at 17:28:12 from (207.13.114.118):
In Reply to: Which dist. does my farmall 300 have posted by CNKS on August 22, 2010 at 16:42:56:
Actually there are two different sets of points for the IH distributors. One fits the four cylinders and the other is used for six cylinder engines. The four cylinder set has the stationary point with just a ninety degree bend. the six cylinder stationary point is also ninety degrees but is also offset about the width of the bracket. Also the rubbing blocks are installed just opposite of each other on the movable part of the point set.
