Re: New project
Posted by Owen Aaland on August 22, 2010 at 17:34:19 from (207.13.114.118):
In Reply to: New project posted by kevinj54 on August 22, 2010 at 17:05:13:
You should get into the habit of not attaching chains on the top of the front frame like you did. There is enough angle in the way you are hooked that you most likely did not do any damage but if the chains go forward, like they would if you were to pull it, you will damage the front hood and possibly the radiator.
