You need the lower outlet that has a plug on the housing for the sender to screw into then you need the bracket that mounts on the gov housing for the guage to mount. You wont be getting any reading on the guage unless you have shutters to get the engine warm as the return water in that system will be too cool for the guage to read. The tractors were made that way to get engine warm enough to switch from gas to the kerosene and you needed shutters to get coolant warm enough for the guage to read. Without shutters you wont get the engine warm enough for a reading. Now if you put the sender in the upper housing you will get a reading as thats where the warmest coolant is.So dont expect to get a reading with sender in the lower housing.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
