Re: Removing paint from serial number plate
Posted by Hill-Billy Rock-Star on August 22, 2010 at 21:02:31 from (68.31.227.235):
In Reply to: Removing paint from serial number plate posted by Hayrake25 on August 22, 2010 at 20:21:42:
I would try a gray scotch brite pad ang some thinner to try and brake the surface of the paint then a rag and thinner. If the tag is still messed up you can always get a replacement with the rivit's from Stiner's tractor parts.But you will have to stamp all your number's in yourself. Hope's this helps.
