Re: 400 Rear End Oil
Posted by Wardner on August 23, 2010 at 10:09:03 from (4.154.237.192):
In Reply to: 400 Rear End Oil posted by Ohiohillbilly on August 23, 2010 at 09:19:43:
If your TA was working, it will probably stop working. But take heart, you haven't damaged it. Replace the oil.
If the TA wasn't working, I wouldn't go to the expense of changing it until you fix the TA.
My 400 ran for years with something that looked like roofing tar. The previous owner (first one) probably dumped the factory oil after delivery. After I bought the tractor, I changed the oil and the TA started working fine.
