Re: M-TA diesel efficiency
Posted by Janicholson on August 23, 2010 at 12:24:35 from (199.17.6.223):
In Reply to: M-TA diesel efficiency posted by Leo Davinci on August 23, 2010 at 11:53:08:
It is a good low compression (~16:1) diesel (meaning it is more economical than gasoline engines, and it was as good on fuel as its contemporary fellows. The Nebraska tractor tests can give fuel at rated power per hour for almost all tractors. A modern direct injection high compression diesel with turbocharger can out perform these by 10% or more. Jim
