farmall H transmission question
Posted by Mark on June 12, 2000 at 16:55:29 from (199.183.76.227):
Hello;
I have a 1951 model H Farmall that is having a problem with 4th gear. It seems to engage ok with the shifter, but as you let the clutch out it pushes out of gear. This is only a problem in 4th, it stays in gear in all the others even under heavy load. Everything seems tight when put in gear, not much slop. Any ideas? Thanks....Mark
Post A Followup
: Re: farmall H transmission question
