Re: Farmall 400 Help Please!
Posted by AJB450 on August 23, 2010 at 18:58:28 from (98.115.137.115):
In Reply to: Farmall 400 Help Please! posted by Chris Balogh on August 22, 2010 at 20:11:19:
Chris, One other thing that was not mentioned. Had a similar problem with a 350 I bought. Rebuilt carb, ignition, etc. Problem turned out to be the intake manifold gasket. You could adjust the carb to run good at idle but then when you open the throtle, it would stumble and seem to miss. Al
