The TA in a 656 works like a 2-speed Powerglide automatic transmission, except that it's shifted manually by a lever.
In an oversimplified nutshell:
The TA unit sits in between the engine and the transmission so it has an effect on all gears.
There is a clutch and a planetary gearbox inside the 656's TA. The TA lever engages and disengages the clutch.
When the clutch is engaged (TA lever ahead), it locks the planetary gearbox and spins it as a unit. The gearbox acts as a solid shaft and gives you DIRECT drive to the transmission.
Pull the TA lever back, and the clutch disengages. Now the planetary gearbox goes to work and reduces the RPMs from the engine to the transmission. This gives reduced speed, but multiplies the torque from the engine.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
