Just to follow up on Gene and others, all the ideas for stripping will work just go slow and easy. As fara as the black, it's recesses in '45. On my '47, I cleaned it up with a Scotchbrite. After taping over the flat spots where the numbers get stamped, I hit it with several thin coats of black acrylic lacquer, then wet-sanded down with 1600 or 2000 grit. Had to to go back over it several times to get it right before a final coat of a clear lacquer, but the International Harvester and other printing on there is actually lightly stamped so that it is raised above the black background.
