Re: 1086 1st gear
Posted by Larry B 1486 on August 24, 2010 at 17:40:35 from (67.142.161.29):
In Reply to: 1086 1st gear posted by MikeRamey on August 23, 2010 at 12:06:17:
If it happend all at once loosing first gear in all ranges, most likely nut came off the counter shaft dropping first gear down. Happened to me on my 1486 two years ago. If that is the case, you will have to replace the counter shaft also. My TA was bad also so had it all fixed at the same time. Parts and labor ran me $2,685.00 for it all, transmission fix, TA, front pump, clutch & pressure plate and labor.
