Re: Shifting Technique
Posted by Tom Fleming on August 24, 2010 at 17:56:07 from (206.193.253.243):
In Reply to: Shifting Technique posted by REDRYDER on August 24, 2010 at 12:48:41:
have you tried double clutching it? cut the throttle back to about 1/3 and let her slow down a bit. Clutch into neutral, and run the throttle back up a bit. Clutch it again, and put it into the next lowest gear.
Edit: I re-read your first post, and I see that you have tried double clutching. That should work if you are doing it right. IMHO
This post was edited by Tom Fleming at 03:00:23 08/26/10.
