I used to put a lot of perfect circle valve seals on those engines, and with wear the rocker arms will throw more oil on valve guides than when they were new. The compression rings do indeed have alot to do with oil comsumption, IH several times over the years changed only the compression rings to help control oil consumption. That is why they make several different types of compression rings like barrel face, taper face, torsion grooves in inner and or outer side of ring. Install a taper face compression ring upside down and watch it use oil.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
