Re: SA Carb not adjusting
Posted by old on August 25, 2010 at 17:50:41 from (4.245.5.40):
In Reply to: SA Carb not adjusting posted by TWheat on August 25, 2010 at 17:42:11:
That carb does not have an adjustable main jet on it. First off have you serviced the air cleaner??? If you have not that could be your problem. Or you may have a bad main jet that has been drilled out or worn out. Main jet is in behind that little bolt looking plug on the bottom of the carb that points forward
