The wire from the starter to the amp gauge is the main hot feed wire....Then loads like lights and ignition etc etc are all fed off the amp gauges other load side terminal. That (or L if it had a 4 terminal Voltage Regulator) then feeds hot voltage to the ignition switch which feeds the high input (NOT to distributor) side of the coil when its turned ON
Get the test lap and place it on BOTH sides of the coil like my procedure shows and see if on the low to distributor side it flashes on and off like it MUST. if the ign switch isnt feedign voltage down to the coil simply hot wire it by passing the switch n see what happens.
Run my test procedures at my URL link to see whats wrong, piece of cake with only a test lamp
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
